1 - 8 of 8 Posts
I have an 05 zx4 st. The oil pressure light flickers on an off. It seems to happen at 60mph or higher. I have changed the oil and filter, pressure switch, and cleaned the pick up tube. Is there something that I am missing
Possible short in the switch wire. Mechanical gauge installed to check the pressure and if still low engine wear or damage.
Same thing just started happening here.. except I just did a 25 swap.
Had to swap the filter tap to the new engine and I reused the old gasket. It kinda looks leaky
ive put a few miles on it.. engine had 33k at the swap so its broken in. Will be checking it out when home and looking at wiring
Hello, everyone.
My car have a problem, red oil light is always on, i check oil level and oil pump and evrithing is OK. Someone knows this problem?
1 - 8 of 8 Posts
