1 - 3 of 3 Posts
i went to everybodies favorite friend boost! so i also decided that i wanted a oil pressure guage! i comes with a sender unit, does anybody have any freak'n clue how to do this!also were is vaccum tube for the boost guage?
You can hook up your boost line to your PCV on the intake manifold. Important you must hook it up after the throtle body. Run the hose thruogh the fire wall. (I used the factory gromet for the clutch cable) For the oil pressure, depending on what type, more then likely you have to tap into your block for the sender.
This is just a picture I have online already...
If you look where I circled, that is where you'll find the pcv line to tap into. That's the little black one, just get a Y fitting from Advanced Auto Parts. Tell them what it's for, they SHOULD know what you need.
1 - 3 of 3 Posts
