1 - 7 of 7 Posts
This is sorta more of an FYI.
I use to own a 2002 Dodge neon and always used PL10241 Purolator oil filters, guess what thats the same one the 2012 Focus uses! Now I know the Focus was meant to be mine! All I did was go to amazon.com and search oil filters for a 2002 Neon and you get alot of options! I did my first oil change with the filter left from Neon and it fits perfectly. Hope this helps some people.
Here is the 2012 filter # at Purolator filters http://www.purolatorautofilters.net/resources/Pages/ApplicationGuideResults.aspx?mid=35&modid=958&yid=91&make=FORD&model=Focus&year=2012
Discussion Starter #2
Here is a list of filter #'s that should all work
K&N HP-1002 High Performance Oil Filter
Purolator PL10241 PureONE Oil Filter
Mobil 1 M1-102 Extended Performance Oil Filter
Wix 51348 Spin-On Oil Filter
Purolator L10241 Classic Oil Filter
Bosch 72161 Premium Oil Filter
Fram PH3614 Extra Guard
Fram TG3614 Tough Guard
Bosch D3330 Distance Plus High Performance Oil Filter
Bosch 3330 Premium FILTECH Oil Filter
ACDelco PF53 Oil Filter
Baldwin BT223 Heavy Duty Lube Spin-On Filter
Fram XG3614 Xtended Guard
Once I get back from the cabin this weekend I'll post pics of the FoMoCo filter that I took off. Looks like the crimp where the "shell" meets the base was bad. filter had oil on it and the engine cover you take off for the oil change had oil on it too. I'm glad I did the oil change when I did.
1 - 7 of 7 Posts
