1 - 18 of 18 Posts
i need to find a place to tap into the motor to get oil to the oil pump then to the turbo....i kno there are like 2 or spots on the motor....just dont kno where.......need help please
thanx for the thread.....but i just need an answer to a question.....if i tap the line off the head and send it to the pump....is there gonna be enough oil to send it to the turbo?....or do i need to drill it directly into the oil pan?...im trying to make this as easy as possible.....thanx
...sorry i'm lost, What pump are you sending it to...?
I think he has the precision kit. The one that uses a pump for oil return from the turbo. I think finalley was showing you how to get oil to the turbo. The pump is to get the oil back to the pan. I am not familiar with that kit myself but I am sure others on here could help you out. BTW not tryin to be rude but didnt the kit come with instructions? Good luck.
...well seems to me , your eng oil pump feeds your turbo , which drains into your aux. return pump, to the oil pan...No??[???:)] why do you want to feed the retun pump off the engine supply oil??
I think he may be confused on what the pump is actually for.
whats a pump
lol
Discussion Starter · #9 ·
well now that u all say so.....i probably am confused on what it is used for.....i blew my motor a couple months back with the kit on it.....now i am going to put it back on.......so what everyone is saying is i need to tap it into the oil pan???//correct???....is that a hard task to complete'????/.....trying to get this done in a 3 day span
yes the pump is to "pump" the oil back into the oil pan. this is because the turbo sits to low and the laws of gravity work against you. you will need to weld a bung into you oil pan. you have the precision kit right?
Discussion Starter · #11 ·
i need to weld it?.....isnt there way to drill and just attach?....yes it is precision kit.....rally need a reply....doing this on tuesday....thanx
I dont think the oil pan is near thick enough to drill and tap as you had mentioned earlier.
Discussion Starter · #14 ·
i am not changing anything.....when i blew the motor i 4 got to take the oil pan that was on the blown motor....that pan had the connector for the pump that comes with the kit.....now sitting here 2 months later....i need to find a way to tap the oil pan for the pump.....just need to know how
buy a bung, drill a hole, and have someone weld it to your oil pan.
Discussion Starter · #16 ·
ok....next question.....there are two oil lines that come up from the turbo.....i dont want to seem like and idiot....but where do i hook these up to?.....when i took off the turbo i rally didnt retrace my steps because i wasnt plnning to put it back on....so if anyone has a pic or something of a kit installed that would be great....thanx for everything guys
ok, I have aquestion.. if you are having to use a pump anyway.. why not use it to pump oil in AND out of the turbo, with a container of course, leaving your engine and turbo oil uncantaminated from each other?
Discussion Starter · #18 ·
i really dont kno the answer to thta....but maybe....so you have a reliable source of oil....be my guess......i duno
1 - 18 of 18 Posts
