1 - 5 of 5 Posts
I switch my summer tires out to som winter today and my back rear tire the inside tread was all wore down, the rest of the tires are fine. What does this mean?[???:)]
Is the worn out area smooth or feather-edged. If it is smooth, the camber is incorrect. If you can feel the feather edging when rubbing your fingers over the thread, the toe-in adjustment is off.
Are you lowered? Your camber is way off. Get an alignment.
if they r flat then it is an alighment issue, if they r scalloped it could also be your struts
1 - 5 of 5 Posts
