1 - 5 of 5 Posts
2011 Focus - 9000 miles (a lot of which are city) 5 speed. I'm going to try to get a video of it
I have an issue shifting from 1-2. If I let off of the gas completely during my 1-2 shift, I have an EXTREMELY hard time getting it into second; it usually requires me to double clutch, return the shifter to the center position and go to 2. Otherwise I get a bit of resistance or have to force it - which I NEVER do
IE - push in clutch, put in neutral (center between 3/4), let out clutch, push clutch in, back into 2.
Now, if I push in the clutch and DON'T let off of the gas completely, I have zero problems going into 2.
IE- Going at maybe 2000 RPM in first, I decrease throttle a bit so the RPMS stay at 2000, push clutch in and right into 2 it goes with no problems.
Is this normal? Am I missing something?
2
Hi Miller88,
If your shifting resistance started recently, you should bring your Focus to your dealer so it can be inspected. If they aren't able to resolve your concern, I am here to help. [:)]
~Natasha
It's only when the RPMs are close though. If the RPMs are far apart - IE I wind it up to 3000RPM for a shift, it isn't hard.
1 - 5 of 5 Posts
