Zetec t-stat housing alternatives
Not the typical zetec thermostat housing leak in my opinion although that may be the cause. I noticed my lower radiator hose is about to blow so I changed it. The coolant was leaking before from over by the thermostat housing. When I replace the lower radiator hose the valve cover started leaking but the coolant leak stopped from over by the thermostat housing. So I replaced my valve cover and gasket nownmy coolant leak is back.
But my coolant only leaks when the car is cooling off. Still on that side of the motor but why would it do that. Seems to be linking up the backside to my knowledge the thermostat has never been changed same for the housing.
Any ideas ? Maybe I should check the torque on the bolts for the thermostat housing?
