1 - 18 of 18 Posts
I saw that the other day, define "lightly used"
why take it off?
are there any other modifications needed to be made to run this header? Example; i have an fswerks exhaust, can I bolt this on or will custom work need to be done for proper install?
Discussion Starter #8
It matches up perfectly with the factory exhaust. I don't know anything about FSWerks exhaust. If your FSWerks matches directly to the stock header/cat assembly then you should have no problem.
good lawd jesus this is tempting
Discussion Starter #14
Did you get any check engine lights while running it?
No and I used the factory sensors: The upstream went in just like factory. On the downstream sensor I added an extension (included) and a couple of washers so that sensor is not directly exposed to the exhaust gas as it flows by.
#dailydriven
I can't get on ebay on my work computer lol. how much is the price now?
#dailydriven
did you sell it?
1 - 18 of 18 Posts
