1 - 3 of 3 Posts
My daughter's 2002 Focus was acting up. I was thinking that it could be a coil problem so I headed off to the parts store to borrow their code reader. Number four cylinder misfiring, so I bought a new coil pack, installed it and then headed back to the parts store to clear the codes. That got me to thinking.
I drive a Volvo and I have diagnostic software (Vida) and a Volvo specific box (DICE) that plugs into the OBD2 port. So I thought, "There must be ODB2 software for the PC." I found that there is a plethora of cables out there ranging in price from $5 to $50. Some say that they are for Toyotas or VWs which might be related to the included software.
One article that I found said that "a cable is a cable" and that it is the software that is important.
Any thoughts on cables or software?
Thanks.
Be aware that most devices out there (your 'box') that claim to be the standard 'Elm 327' chip type commonly used to read OBD on a PC are actually cheap Chinese clones that will work to varying degrees. The Elm chip alone goes for about $40 so you can tell whether they use the real chip or not by the price of the device.
I've discovered that about the ELM chips. BTW, the chips are down to about $20 each for onesies and twosies.
I'm now looking into whether my Volvo DICE box will play with other cars if I have NonVolvo specific software.
1 - 3 of 3 Posts
