do it yourself... it's simple. Only trouble you might have is the sensors being too tight... you can use a 02 sensor removal tool which can help greatly. You can also use vise grips too. Heat helps too. Mine wouldn't budge with any pb blaster and such so i used my torch and got that nice and hot... came right loose. once you are under there bud you will see exactly how simple it is.
