1 - 7 of 7 Posts
is it true this is needed?
Well some people need it because their CEL comes on when the cat is installed and never goes off. It is indeed a high flow cat so your computer might not like it. Try it out and see what happens.
AKA Toyotech
the cheat is NOT needed, it is a fully functional cat and unless the o2 sensor was damaged, you should not have a problem
Discussion Starter · #5 ·
aright thanks kickn
yeah those can be some sensitive little bastards too, but do the install right you should have no need for a cheater anymore than you do now w/ the stock cat
Sure a cheater is NOT needed but if you're throwing a code when you take it for emissions testing for your OBDII system then you're gonna have to do something. Either purchase the cheater or put your stock cat on for the day.
1 - 7 of 7 Posts
