In stock in the USA at Massive Speed! Turbosport Ltd Light Adjustable / Vernier Cam Gears / Sprockets!
Massive is the sole importer of what we now believe to be the ONLY Adjustable gears for the Duratec in the US!!!
Fits:
Duratec / MZR Motor
2.0 2.3 2.5 originally equipped in Ford Fusion Focus Ranger Transit Connect Escape Mariner
Mazda Miata MX-5 Mazda 3 5 6 Tribute Axela
NON Turbo NON Direct Injection NON Sky activ
Allows positive and negative adjustment for essential degreeing /tuning of camshafts. Billet construction looks good and will last forever. Sold individually. Includes all hardware.
All Steel. Fully lightened gear is an astounding 39% lighter than OEM gear (6.6 ounces lighter!)!!! Reducing valve train weight is crucial for your high RPM build! Offers a full 14 degrees of adjustment each way! Drilled for dowel pin should you wish to fix to camshaft. Custom counter bored steel washer is locked down by grade 12.9 socket head cap screw for free adjustment for the long term. Fits any Duratec or MZR engine 2001 - present. Would need Massive VCT Delete kit to use as VCT gear replacement. We recommend converting to the stronger /superior 38 tooth style gears/chain/etc. Sold Individually. 50 tooth gears also available.
SOME Fusions / Mazda 3/ 6 / MX-5 etc had inlet side VCT. This can be used on OE Exhaust cam, or inlet side when used with Massive VCT delete - this is a great way to be able to run inexpensive Duratec Non VCT style aftermarket cams!!!
Manufactured IN the UK!!!
JUST $98.73 each!!! [HIGHLIGHT]CHEAP![/HIGHLIGHT]
Find em Here
Fits:
Duratec / MZR Motor
Find em Here
