So I noticed late Friday after driving on my new 17" wheels for a day (coming from my stock 15" wheels) that I am getting what sounded like a grinding sound from the front left accompanied by vibrations. It happens when driving straight at any constant speed (at low speed, 5mph or so, you can hear the grinding sound repeat itself at the same interval, as you get faster it turns into a constant grind and vibration due to wheel spinning faster). Left turns also exhibit the sound and vibration. When the wheel is turned right, all vibration and noise is nonexistent.
This lead me to believe that a CV joint on the left axle went bad quickly (I haven't ever seen one to that bad that quick). Yesterday, I visually checked the boots, with no rips on them. I also checked for wheel bearing failure, and that seemed fine as well. I sprayed the hub/spline area with pb blaster as I was thinking that I would be replacing the axle in the near future.
I decided to call it a day and take the 17"s off to clean and put the stock wheels back on. I needed to step out to pick up a few things, and noticed that all grinding and vibrations disappeared. Totally gone. I checked the front left wheel for any rubbing, but there are no signs of it.[scratch]
Any ideas of what this could be? I would think that if it was a CV joint it wouldn't matter which wheels are on the car, though I could be wrong. The only thing that maybe could be an issue is I have had a squeak when I go over the curb in front of my driveway.
