1 - 12 of 12 Posts
well everytime or atleast almost everytime i put the car in either first or reverse , i give it gas , bewgin to release the clutch and just as it is catching before the pedal it completely released , it lets offf a very loud scheeching/squealing noise that is annoying and embarrassing , it drives fine just makes this nose to top it off the clutch was just replaced not more then maybe 1.5k-2k miles ago.....any ideas anyone , any input is greatly appreciated....
SVT Fanatic
who installed it? maybe it has something to do with the installation or the clutch itself. was the flywheel replaced also? i don't know much about them so sorry i can't help you much.
Mine was replaced a couple months ago under the TSB and is doing the same thing. I put about 12k miles on the car in two months (yes, I drive a lot) and it's not doing it as much. I took it back but they couldn't get to duplicate it. It almost sounds like a dust shield or something is rubbing/wearing against a rotating assembly, but could very well be something else.
My POS Spec stage two clutch does the same thing-loud squeal when releasing it when hot. Going with Centerforce replacement. Spec clutches suck.
take it back to the installer...
SVT Fanatic
yeah it sounds like it's either something wrong with installation or the clutch itself isn't right. i wouldn't hope a squeel from a clutch would be normal. if it is, i won't ever be buying it lol
1 - 12 of 12 Posts
