1 - 6 of 6 Posts
hey guys,
I recently belw my svt up and I put a new engine in I hve everything connected but I have no spark. any ideas on what could be wrong? could that sensor that goes thorugh the block and behind the flywheel be bad?
Thanks Jamie
FF Affiliate
I take it the engine you put in was from an SVT as well ?
Yes the crank trigger sensor (thorugh the block and behind the flywheel) could be bad , Check the connection first then the sensor
yes it was from another svt the connector does not look to healthy how would I check that connector to see if it is good? and do those connectors usually go bad? what other sensors might prevent me from getting spark
Jamie
1 - 6 of 6 Posts
