Only the very early build 2012 model Titaniums came with an engine cover.Hello all,
I apologize if this has been covered before but I recently picked up a '14 Titanium and it has no engine cover. Was this a change for the '14s? I feel gypped.
Thanks
Dave
Only the very early build '14s?Only the very early build Titaniums came with an engine cover.
12s, no late 12s, 13s or 14sOnly the very early build '14s?
Thanks for the info.
Dave
Mine's not too dirty.I guess they just stopped putting them on to save money? Does it help keep the top of the engine cleaner? I have seen some pics of some focus's with a ton of crud on top the engine.
It's a Duratec.Mine's not too dirty.
Isn't the cover technically incorrect?
The MK3 doesn't have a "Duratec" engine, but rather the still-unnamed "2.0L Ti-VCT".
Maybe I'm confused.
Guess you showed me. That's what happens when you don't read the details.It's a Duratec.
"Ford invited media this week for a deep dive on the new Duratec 2-liter gasoline direct injection (GDI) 4-cylinder engine that is the standard powerplant for the just-coming-to-showrooms 2011 Focus"
http://www.edmunds.com/autoobserver-archive/2011/03/fords-new-big-gun-in-small-car-engines.html
Yep. Just ordered the kit. $74 to my door.One stop shopping:
http://www.partscheap.com/2012-2014-Ford-Focus-Engine-Cover-2-0L-Duratec-p/cp9z-6a949-a.htm
comes with everything needed, Wavsine parts number might be cheaper separately, check with your dealer....
The engine cover designed for the MK3 N/A and MK3 ST are meant to serve a few functions, one being to "clean up the engine bay appearance" as not everyone wants to see the top of the engine, the other and more important issue is the sound absorbing dampener pads attached to it as well as the plastic it self being a sound barrier to further help isolate the cabin from the engine's sometimes harsh vibrations (especially on the N/A which seems rougher at idle than the ST is).I find it more raw without the engine cover ... I like that! YMMV
Anyway every duratec 2.0L (from MK1.5) I've seen never had a cover!
Personally, I don't like engine covers. I like to see the actual motor of a vehicle, not a plastic shroud covering everything up. And it's just more junk to have to take off, when working on the car.I find it more raw without the engine cover ... I like that! YMMV
Agree. I like the look of the cover. Opinions vary on this but IMHO, my engine is slightly quieter at idle with the cover on. (As suss mentioned, the cover has noise dampening material on the bottom side) Another benefit of the cover is it protects some electrical components when you wash your engine compartment. I just stuff a plastic grocery bag in the oil dipstick hole and the oil filler cap hole and spray away.Back when manufacturers took pride in the appearance of their engines, even on the cheaper cars, I wouldn't have seen any point to a cover. My '86 & '91 Civic Si's had great looking valve covers and no visible wires, except the spark plug wires. Those were engines worth showing off. These ugly plastic valve covers and the accompanying coil packs and wires on newer cars are just ugly. Definitely needs to be covered up.
