1 - 10 of 10 Posts
im trying to figure this out but cant i have a 04 focus that i bought it has a 2.0 split port i replaces the motor and went to fire it up and nothing no starter starter wont even click fuel pump is not kicking in and also the odomiter where it says the miles has nothing all the lights work radio works blower for the heater wipers work i checked the ground i checked all the relays i replced the wire harness i unhooked the battery for a half hour still nothing cant figure it out if any body can help me i would be thankful
C2H5OH
Check and make sure you have an ECU fuse ... I can't recall where it is, but it's in the underhood fuse box.
Odds are you just forgot to hook something back up.
How many grounds do you have?
That sounds like an ECU hose is blown. You might want to find out where the radio noise suppressor is on an SPI. If you ground that wire you can blow a fuse that won't allow the car to start. That is a black wire that should not be grounded. On other engines, it's grounded on the front rt (pass) strut tower. It looks like a black box. If the box, noise suppressor, is missing, then if you ground that wire it blows a fuse.
I hit a cow with my 2005 2.ol, it drove home ok, but will not turn over, has a clicking noise in the intake manifold, the intake manifold tuning valve? broke off, but the clicking noise comes from another part of the manifold. Would the antitheft system cause it to not turn over?, I took the starter off and it spins good.
You hit a cow. Check the battery cables, and make sure that there's no damage to the engine compartment- especially the air cleaner and air intake if you hit on your side.
Yeah, it has a cracked throttle body and a little thing that sticks into the intake manifold that auto zone calls a intake manifold tuning valve, but nobody sells it, I will probably just plug that off and install a new throttle body, but, it should turn over, i hooked up anew cable.
That's called "Intake Manifold Runner Control" in other places. It's what turns the tumble flaps. There is a tumble flap delete kit available. Pics would make sure we have the right part that's damaged. The IAC is in that area as well. It's available everywhere.
Discussion Starter #8
im trying to figure out what amp the ecu fuse is any body know or where its located at in the fuse box and also now the raio turned on but no sound they turned it off and know radio wont turn on and on the odometer reads ------ just like that got me stumped if any body knows any thing thanks
C2H5OH
"-----" means the ECU is not sending a signal to the gauge cluster and most times not powering up.
IIRC the ECU fuse is a 10 amp one, you can get a free copy of the owners manual here --> http://www.focusplanet.com/#Focus Owners Manual It will list the fuse locations.
1 - 10 of 10 Posts
