1 - 2 of 2 Posts
if you put in a downpipe in place of the stock CAT but the downpipe still utilizes the factory o2 sensors will it set the check engine light off. im pretty sure it does but i dont no and if it does do i just have to get one of those MIL eliminators and ill be set? and do i need only one for the o2 sensor that would be after the CAT or do i need one for each o2 sensor. Ohh yeah one last thing when u use the MIL elimanator the o2 sensor is still functional correct? like it still sends infor to the ECU to control ur Air/Fuel ratio.l I know thats alot of question but i just cant afford to make any mistakes thanks for the help guys
You only need the O2 cheater for the downstream sensor...if you put one on the upstream sensor, your engine will think you're running super lean and will make the A/F ratio waaaay too rich.
1 - 2 of 2 Posts
