Today I installed the Stg1 turbo kit (removed from Mike's 2004 SVTF) to my 2002 SVTF. Idle is fine, everything *seemed* fine. When I went for a drive, under load and when boost should be coming on it sounds like a rev limiter and it makes no boost. It literrally feels like I have a parachute tied to my car and I just cant go. Its as if the computer senses the boost and freaks out.
Just so you know, mods are: Stg1 with T3 upgrade, MAFia (set at 4), 55lb injectors, Greddy BOV, MSD Coil and Wires and OEM Plugs, Ex.Cam Gear (set at 0*-1* Advance - as close to zero as I could get), UDP, No Cat, 3" Exhaust.
I didnt unplug my battery (its in the rear of the car and didnt think of it) til I was already gone. But, I flashed the custom tune and it went just fine.
Also, if its relevant, as soon as I start to drive away, the air fuel (aem wideband) pegs rich (goes below 11:1) and it sort of sputters. It only does that on vey light acceleration. The car also stalled out several times but I figure with all those symptoms that its just learning.
The making no boost is the biggest issue. Do you think its a tune issue or something mechanical. I will tell you, the turbo kit was FINE as it was removed from the car. The BOV is hooked up right, wastegate is hooked up right, etc. Also, I have an RLA6 car, and Mike has a ZED0 car...could that be an issue?
p.s. I ruled out traction control (light doesnt blink, and I also pulled the fuse so it was gone...)
Any ideas??? Im at a loss...
Thanks
Russell Rudez
Thanks
Russell Rudez
