1 - 5 of 5 Posts
Alright i am just about to purchase a NX kit with the items to make it run properly. I am going to run a 50 shot. Right now i have a diablo flash tune but i have read constantly that if i use it while spraying it will retard the timing. I also heard that there is a tune you can get so when you aren't spraying it works but when you spray it doesn't(i think it goes like that). I just want to know how to get this tune and how much it will be.
for something like that you'd need a standalone ignition control box like an MSD DIS-2. you can run the regular tune that you have, and when you hit your nitrous button, the switch sends a signal to the DIS-2 box to pull a programmed number of degrees of timing. you'll need to go get dyno tuned to find out the proper timing for the nitrous.
1 - 5 of 5 Posts
