1 - 13 of 13 Posts
Hello All:
We just released our new Steeda Focus Rear Shock Tower Brace (13-14) - http://www.steedafocus.com/parts/steeda-focus-rear-shock-tower-brace-13-14-555-5753
Steeda's rear shock tower brace was designed and tested on our own in house Focus ST, and manufactured in our state of the art facility. This brace is manufactured using high strength chrome moly alloy steel tubing making this brace stronger than any mild steel offering. This brace will reduce rear chassis flex from suspension loads during cornering and over rough surfaces improving handling performance and long term chassis longevity.
Best Regards,
TJ
What is your email address? I can send you a copy of the instructions so that you can see the steps that are involved.
Best Regards,
TJ
The ImpoSTer
Mike has modified one to fit our sedans
We have not tested it on the sedan.
Best Regards,
TJ
Discussion Starter #10
This does fit the hatchbacks. It does not fit the sedans. Yes, made in the U.S.A!
Best Regards,
TJ
Discussion Starter #12
The shock tower brace is designed to stiffen up the chassis.
It improves handling by reducing chassis flex.
This allows the tire to stay planted to the ground during hard cornering.
A swaybar is a part of the suspension, not the chassis.
It's job is to reduce body roll and improve the balance of the car by reducing understeer.
It dose this by increasing roll stiffness of the car at whatever end it is bolted to. (Front or rear)
If you are interested ... feel free to hit me up for a discount code!
Best Regards,
TJ
1 - 13 of 13 Posts
