FYI: I ran across these while looking for something else. For you LED fans out there. There is a 10mm LED that contains 5 LED chips. The brightness is suitable for single applications like tail light replacement (although, you may have to mount them backwards so they shine off the reflector). Viewing angle is only 40 degrees, but you might be able to make them work. there rated 260K mcd (260cd) minimum so they should be plenty bright. (note: 260 cd is (roughly) 260 candelas. Or 260 candle power. There is no conversion to MSCP (mean spherical Candle Power. such as a incandescent bulb)). I.E. there still going to glow in one direction. So keep that limitation in mind. Given that, the stock 3157 bulb is rated 32/3 MSCP. So you can possible see why I say 'plenty bright', but not necessarily in a useful way.
Here is the link.
http://www.ledssuperbright.com/10mm-led-c-9/10-10mm-extreme-bright-led-wired-155000%2B-mcd-p-240
Here is the link.
