From a different thread:
P0171/P0174
Examples: MAF sensor measurement inaccurate (corroded connector, contamination/dirty (a contaminated MAF sensor will typically result in a rich system at low airflows (PCM will reduce fuel) and a lean system at high airflows (PCM will increase fuel), etc).
Vacuum Leaks/Unmetered Air:
With this condition, the engine may actually run lean of stoichiometry (14.7:1 air/fuel ratio) if the Powertrain Control Module (PCM) is not able to compensate enough to correct for the condition. This condition can be caused by unmetered air entering the engine, or due to a MAF malfunction. In this situation, the volume of air entering the engine is actually greater than what the MAF sensor is indicating to the PCM. Vacuum leaks will normally be most apparent when high manifold vacuum is present (for example, during idle or light throttle). If freeze frame data indicates that the fault occurred at idle, a check for vacuum leaks/unmetered air might be the best starting point.
Examples: Loose, leaking or disconnected vacuum lines, intake manifold gaskets or O-rings, throttle body gaskets, brake booster, air inlet tube, stuck/frozen/aftermarket PCV valve, unseated engine oil dipstick, etc.
Insufficient Fueling:
With this condition, the engine may actually run lean of stoichiometry (14.7:1 air/fuel ratio) if the PCM is not able to compensate enough to correct for the condition. This condition can be caused by a fuel delivery system concern that restricts or limits the amount of fuel being delivered to the engine. This condition will normally be most apparent when the engine is under a heavy load and at high rpm, when a higher volume of fuel is required. If freeze frame data indicates that the fault occurred under a heavy load and at higher rpm, a check of the fuel delivery system (checking fuel pressure with engine under a load) might be the best starting point.
Examples: low fuel pressure (fuel pump, fuel filter, fuel leaks, restricted fuel supply lines), fuel injector concerns, etc.
Exhaust System Leaks:
In this type of condition, the engine may actually be running rich of stoichiometry (14.7:1 air/fuel ratio) because the fuel control system is adding fuel to compensate for a perceived (not actual) lean condition. This condition is caused by oxygen (air) entering the exhaust system from an external source. The HO2S will react to this exhaust leak by increasing fuel delivery. This condition will cause the exhaust gas mixture from the cylinder to be rich.
Examples: Exhaust system leaks upstream or near HO2S, poorly welded/leaking HO2S boss, malfunctioning Secondary Air Injection system, etc.
My Car has always idled very low...
Should I check vacuum leaks first?
Im not going to drive it to work today.
Going to let Her sit and use the wife's Freestyle.
Any ideas,please post them up,I cannot respond back till later tonite.
Help and input appreciated!
