1 - 18 of 18 Posts
· Registered
I'd like some opinions here and I'm curious if anybody runs an aftermarket fuel pump, what kind it is and what kind of power rating is it good for?
Also what kind of power can I expect out of the stock 2001 fuel pump with and without the BAP? Also how hard is it to tune with the BAP?
Thanks
(PS this is in the FI forum because only FI cars tend to have these problems and also my car has FI and I'm going to aim for about 300whp with all other required mods)
· Registered
I would think you'd need a bap for that kind of power
· Registered
Oh I know the stock pump alone won't handle that power goal, but I'm mostly just curious is anybody is running an aftermarket fuel pump or if they're just running stock pump with BAP or whatnot.
· Registered
aren't the pumps in the zx3 different from the ones in the svt? if they are, just snatch one from an svt or order one and put that in there.
· Registered
Tom,
I'm running 15psi (probably closer to 250whp) and my fuel pressure is dropping off to 32psi at WOT at the top end of my 3rd gear pull. This is with a full tank of gas and the recall pump installed.
IMO I'd go with the BAP to be on the safe side, but you can datalog and make your own conclusions. Better to do it right the first time then blow it up in the tuning process.
· Registered
Discussion Starter · #9 ·
so wasn't there like a warrenty or TSB about the early fuel pumps where the dealer would put in the new style for free? More info on this would be wonderful kthanks! it bolts straight in right?
· I AM DA FOCI FANATIC
^^so you just went up to the deaership and said "I want the new style fuel pump for free" and they did it?
Not exactly, I told them I was having cut out problems with my fuel pump and that to my understanding there is a recall/warranty.
They said yes, I said great it was done in 1/2 a day.
· coffee, have some
You can change a fuel pump in a couple hours if you know what you're doing (i've done it twice now lol).
The hi-flow pump from Focus CFM is great. Comes with everything you need.
· Registered
Response to question from earlier--yeah, it's the upgraded replacement pump, and I still see that much pressure drop. And I'm told that with more boost it'll only get worse, which makes sense to me because at 9psi I had no pressure drop and at 15 I do. Either way I'd go with a BAP because there is no other alternative if you are having pressure drop and don't want to retune. If you get a aviator or GT pump you have to get a retune and a return style fuel system obviously is totally different.
1 - 18 of 18 Posts
