1 - 3 of 3 Posts
Illegal Alien
I replaced my stock throttle body with a Focus Central one about 2 weeks ago, now i'm noticing that my transamision shifts a bit too early than it should, i presume it has something to do with the Tb, cause it had never done that before. I mostly notice it around last gear change, 4th. It shifts way too early than it should.
I have a 2000 Focus Wagon, 2.0 lt Zetec engine, autotragic trans, BTW. Any help is much appreciated.[thumb]
After you installed the TB. Did you unplug the battery for 15 minutes? If not, do so, let the car just idle for 5-10 minutes Don't touch the throttle. It will "relearn" the new airflow somewhat. Try that and see if it helps.
Illegal Alien
Thanks Viney! Yeah, i did that. I actually unplaged it way after atrating the install. I did it afterwards when i found the wierd shhifting and it's still doing it.I have no clue to what's going on.
1 - 3 of 3 Posts
