Coming from a Master Technician, I would recommend re-thinking upgrading to a staged clutch.
There's only one pro to upgrading a clutch:
To handle increased torque.
(Of course saying "I've got a stage 2 clutch" or liking the feel are often used as excuses to upgrade)
There are several cons though! Let's get into those.
1. It's hard on the engine (not a lot, but it is) it causes the engine to have to catch up/slow down much faster than the stock clutch (not a problem if you rev match)
2. Hard on the trans/axles. The power comes in with more impact, causing extra stress to hardened gears, the spiders in the diff, and the CV axles.
3. Hard on the engine. The crankshaft rides on main bearings, but you may not know about the thrust bearings, which keep the crankshaft properly aligned with the engine (think a sideways bearing). The reason staged clutches can handle more power is easy! Stronger springs. Much stronger springs. A stage 2 clutch can increase power handling by 50-100%. That means you are pushing on your thrust bearings 50-100% harder, causing faster wear which can lead to excessive crankshaft end play (which leads to rods/pistons coming misaligned, chain coming misaligned, but the big one is loss of oil pressure through the main bearings).
4. hard on the clutch master cylinder and throwout bearing. Also means 50-100% more pressure in your clutch lines and on your throwout bearing.
Overall, unless you're building beyond the holding limit of the clutch, I wouldn't "upgrade"
Upgrade isn't really the right word. Cause it's just a different part for a different use.
Just my two cents!
Also, I'd use exedy personally.
Sent from my moto g(6) using Tapatalk
