1 - 13 of 13 Posts
I just put the Luk kit in my car and Its alot nicer. The ? I have is to ingauge the clutch, you all most push the pedel to the ground. Is this common or do I have to make adjustment some where. Also how long is the break in peroid. 1,000 miles and not to go over 3k on the RPMs??
Not sure about the break in period, but having the engagement point low on the pedal is a good thing, that's usually how it works with a new clutch. Also, our clutches are hydraulic so I'm not sure how much adjustment can be done.
break in is 500 miles under 3k,
and ya I have to push in my clutch all the way
I have the luk rep set as well
the only adjustment you can prolly do is bleed the clutch some more.
not trying to jack this thread but i also just got a new clutch put in last wed. and i cant get into reverse really at all.. it just grinds and pops out sometimes 1st and 3rd too
Check your shifter cables they might be loose
i'll check it in the morning kind of dark and cold.. but thanks though
i barely have to press my clutch in and i had the luk kit put in in june, i drove like a ninny for a month almost til i reached 1000 miles and then i let that bad boy loose.
1 - 13 of 13 Posts
