1 - 4 of 4 Posts
I am looking for a fuse box with a 'Music Sensor' in it that I can wire several neon bars into so that I can switch between a solid glow and a music induced pulse with the flick of a switch. Does anyone know where I can order one online?
They have them at advanced discount....
Its a sig lighter socket multiplier that can be on/off/music. I am not sure if it glows... and am not sure of the brand off hand. I almost bought it once... it I can find one online I will post the link.,.
Edit:
Just read your entire post... "neon bars"... dude, just get LED or the cold cathode. (unless thats what you ment) I have not seen anything that does that for neon tubes. Might still exist thou.
Most cathodes come with the sound modulation built into the plug thou....
I am assuming that you want all of them powered from the same location so they react the same at the same sound level.
If all you can find is a splitter, just get as many as you need.
Run a Bat lead, and ground it off someplace close to where you will have all of the splitters. O, and the inline switch.
The one I was going to buy only had 3 outlets. So you would have been in the same boat.
1 - 4 of 4 Posts
