Ok so i bought four 6 inch neons. i put 2 in the trunk and hid the transformer in with my spare tire and ran the hidden wire up to the driver side. I wired one under the dash by the driver side and passenger side, then wired it all together and to a switch and blah blah.... got it through the firewall and i have the wires directly on the battery. Long story short, When i turn the switch on, all of the neons come on except for the driver side neon. When i jiggle the wires or play with it a little, it comes on... but not always. Im not sure if its a wiring problem or if its just because the transformer is going.... I thought it was the wiring so i went over all of the wires and the connections are fine... the only bad thing is... im holding the spliced wires together by electrical tape...
All of the other ones work except for the driver side which is giving me a problem...
any ideas?
