1 - 7 of 7 Posts
· Registered
need:Z-TEC AUTO TRANSMISSION oil flush how to-complete with upgrates (royal purple like hints)
hello. i have spend good some time searching for basic: how to on auto trans flush for z-tec motor, and cant find any direct info. What i am looking for is procedure as well additional info (like amount of oil needed or upgrades). Searching i have found lots of good feedback about ROYAL PURPLE products (would "Royal Purple MAX-ATF Automatic Transmission Fluid be satisfactory one?). Is there any upgrade to filter or cooler possible in order to keep temp at the lower scale.
I have found some information for duratec engine does this apply?)..........................
1. Raise and support the vehicle.
2. WARNING: When releasing the transaxle cooling system fluid pressure, cover the fluid hose with a thick cloth to prevent the possibility of scalding. Failure to follow this instruction may result in personal injury. CAUTION: Whenever the fluid cooler hoses are disconnected from the fluid cooler, the outlet and inlet ports must be plugged to prevent the ingress of foreign material. Disconnect the return hose from the transmission fluid cooler.
o Allow the fluid to drain into a suitable container.
3. Attach a length of suitable drain hose to the transmission fluid cooler return hose.
4. Lower the vehicle.
5. Insert the drain hose into a calibrated 10 liter (10.5 quarts) container.
6. CAUTION: To prevent damage to the transaxle, do not run the engine above idle. NOTE: If the fluid return rate is less than 0.95 liters (1.0 quart) in 30 seconds , or if the return hose pulsates, check for restrictions at the pump, cooler or cooler lines. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
7. Switch OFF the engine.
8. Remove the fluid level indicator from the fluid level indicator tube.
9. Add 3 liters of automatic transmission fluid to the transaxle.
10. CAUTION: To prevent damage to the transaxle, do not run the engine above idle. NOTE: If the fluid return rate is less than 0.95 liters in 30 seconds , or if the return hose pulsates, check for restrictions at the pump, cooler or cooler lines. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
11. Switch OFF the engine.
12. Add 3 liters (3.17 quarts) of automatic transmission fluid to the transaxle.
13. CAUTION: To prevent damage to the transaxle, do not run the engine above idle. Run the engine at idle and pump out 3 liters (3.17 quarts) of automatic transmission fluid.
14. Switch OFF the engine.
15. Raise and support the vehicle.
16. Detach the length of suitable drain hose from the transmission fluid return hose.
17. NOTE: Remove the plug from the transmission fluid cooler return port. Connect the return hose to the transmission fluid cooler.
18. Lower the vehicle.
19. Add 3 liters (3.17 quarts) of automatic transmission fluid to the transaxle.
20. Install the fluid level indicator to the fluid level indicator tube.
21. CAUTION: To prevent damage to the transaxle, do not run the engine above idle. Run the engine.
22. Check the automatic transmission fluid level and fill if necessary.
As you can see from the above post, this is no quick and easy oil change.
Thank you for the link or add. info. Bartok
· FocusXtreme
ok here is the simple way raise the car on the driver's side on the bottom of the trans there is a pan. slowly undo one side of the pan with something to catch the fluid under it. after most the fluid has drained remove the pan completely and clean any metal scraps out after all is done replace the pan and fill through the dipstick. for more infopurchase a haynes manual from autozone it is well worth the ten bucks
· Registered
QUOTE=badass3
Yes i would follow these steps, but there is an significant amount oil captured in the converter (i think that's what is called), which has to be machine pumped, or drained through cooling pipe as engine pumps it out.
Therefore i am still in look for complete how to which should be here (I treat forums as the manuals since they have more subjective opinions, saves bucks and trip to store). Still i will look into hanes upon purchase of the oil, but i would like to optimized this oil change to ultimate as it can be done.
thank you for follow up on question. B
1 - 7 of 7 Posts
