1 - 7 of 7 Posts
Hmmmmm
So i was thinking about doing the energy suspension kit and doing the install myself... what do you guys think?
also what other bushings should i change that dont come with the kit?
w/ my magic bag
CFM's tubular control arms & rear toe-link's= win win!
I'd change out the front LCA's for CFM's tubular control arm's= stronger, lighter & adjustable camber, w/ more forward bite, & I'd add rear toe-link's too. A little more cash & a lot less work & a lot more noticeably difference too.[grinking] Well worth the cashola!
Captain Retard
Be careful when you change out the rear springs. Use the top bolt on the spindle, not the bottom, unless you wanna change out the lower control arms. Ask me how I know this.
slow
^^ this is fine if he is replacing the bushings. He'll have to take out the control arms.
Hmmmmm
also my car is not rusty underneath. those bolts come out easily..
slow
When doing the kit, access to a press will make life easier. You will have to push out the old steel sleeves and replace with the ones in the kit.
Captain Retard
That's awesome...........I had to persuade all of my bolts with a sawzall.......doh.
1 - 7 of 7 Posts
