1 - 4 of 4 Posts
I currently have the Ford Rally brake kit on my 2000 ZX3, which is the SVT rear disc (280 mm) and a 278 mm front disc.
I'm prepping my car to get classed in SCCA's ITA class, which limits the fronts to 258 mm (stock) and the rears to 203 mm or stock drum.
Does anyone have any experience with a 203 mm rear disc? I did a quick search of some online part stores and see that they (203 mm rotors) exist, but I'm not sure what hardware works with that rotor size (i.e. calipers, knuckles, etc.).
Thanks in advance for your help.
I believe that would be the rotor from the "advance track" package. Hopefully someone with a little more knowledge on that set up will chime in.
Discussion Starter · #4 ·
Thank you for your message and the comments.
Apparently my reading skills are as bad as my driving skills. SCCA ITA rules permit use of 252mm rear rotors, which are readily available but will require me to use different caliper mounting brackets.
My apologies for the inaccuracies.
Its tough being stupid.
1 - 4 of 4 Posts
