My wifes little focus died on her today and wouldnt start. I got it to start and it sounded like it was out of gas, so I put a couple of gollans in it and it started and still sounded like it was out of gas. I put a fuel filter on it(cheap and easy)on the side of the road. It started and still sounds like its out of gas. When you give it gas it will rev up for a minute then die, if you drop it in gear it will die. I went to check the fuel pressure but theres no fitting on the rail to check it. i dont want to just go buy a fuel pump cause i can hear the pump run. Any ideas? Anybody had this kind of problem before?
Any help would be appreciated,
Thanks
Thanks
