So I am trying to install some clear corners on my '04 ZTS Sedan. This was a simple process on my '05 ZX3 and I just assumed it would be the same this time...but not the case. I got the passenger side installed no problem, but just can't seem to get to the drivers side.
Here is a picture of what I'm running into underneath the front drivers side..
A black box with some plastic tubing running to it from the lower front grille. I'm not sure if i should be trying to remove this or not. Any advice would be greatly appreciated. I also tried going from the top and taking the headlight out, but you have to remove a bolt from the bottom as well...
Thanks guys/gals
Thanks guys/gals
