1 - 5 of 5 Posts
redid some parts of the exhaust, which is now mostly 2.5" all the way through again, so now i need new gaskets, or somthing to use as a gasket, ive checked the main focus sites and see no kits, anyone have any suggestions. I need 2.5" gaskets for both sides of the flex and a short header to cat gasket.
I bought gasket material and permatex at Pep Boys for about $7. I used it on the flex pipe flange to straight pipe. Its holding up fine after about 3 wks.
I used to drive this
Yeah, buy the copper permatex. Worked great for my exhaust leaks when I swapped out the stock cat for a high flow cat.
Discussion Starter · #4 ·
thats what i figured id have to use, and alot of it, i can see daylight on the cat to flex flanges
If the gap is that big may want to pick up some metal gaskets and copper permatex. Were, dunno. There's gotta be some gaskets you can cut to fit too. Do a search, thought someone on here was using suburu STI gaskets that were really thick to seal up tight.
1 - 5 of 5 Posts
