No, I believe the steeda is a rebadged focuscentral tb. Just make sure the gasket seals, and the tps is in the right place. Also if the throttle plate sticks you can adjust that using the little screw on the side. But don't open it to much or your idle will be to high and you will get a cel because the ecu cannot control it.
