Ok, I did this:
At step 2, a dialog box opened saying "The real file size could not be determined, please select the file type from the following list" so I pick SVT Focus (410k) and then I continue with the process. At the end it says "Dowload complete" but the Diablo displays (on screen) "Expected 419840, got 393248" and its not listing a CUSTOM TUNE.
If I go to the dialog box and type in the exact file size (393248) it causes a windows error and shuts the program down.
Whats wrong here? Why wont it load??
To reinstall the new file that you're sent as a "Custom Tune", do the following:
1: On the Predator go to "Options" then "Custom Tune", then select "Import Custom Tune". On the next prompt do NOT hit "Continue", yet.
2: Then in your Predator PC Interface (Xmodem) software on your PC, click "Send File", select the file that you saved that you wish to use, and click on "Open". A "File Transfer Status" dialog box will open up.
3: On your Predator hit "Continue" (Enter). This will start transferring the file.
Note: Remember, if you get time outs or if you aren't getting any communication, to please check your baud settings as you previous did when transferring the file from the Predator to the PC.
4: Install this tune into the pcm as your normally would.
Note: To erase any custom tune out of the Predator and go back to the previous included tuning that came with the Predator default, go to "Options, Custom Tune, Erase Custom Tune".
