Im wondering if i shoudl paint my interior and what i shoudl use i did my neon once with paint but it started to chip after a while is there other ways so it wont chip or good paint if anyoen knows pklz reply
whatever you paint on the inside make sure you follow this.....first clean it with rubbing alcohol..then spray it with primer, then paint, then clear coat.......do this and you should have no peeling problems.
I have a grey interior and painted the trim to match the charcoal I painted the rims and tails. I used Dupli-Color wheel paint and clearcoat for everything. For the interior I washed everything then wet-sanded all the parts then strait to paint-no primer needed as per the instructions on the can.
The result......
