my management light came on and i got the code and fault but i dont understand the problem, thisis what the code and problem is:-
P1518 - Intake Manifold Runner Control Malfunction (Stuck Open) The IMRC system is monitored for failure during continuous, key ON engine OFF or key ON engine running self-test. The test fails when the signal on the monitor pin is less than an expected calibrated range at closed throttle. IMRC monitor signal circuit shorted to PWR GND or SIG RTN
Damaged IMRC actuator
Damaged PCM
An IMRCM PID reading approximately near 1 volt at closed throttle may indicate a fault
could sumone please explain this better and wot i need to do to fix it.
cheers
darren
Damaged PCM
cheers
darren
