1 - 4 of 4 Posts
Across the Pond
Well, i got my car back today from the shop wioth a new clutch installed. Wel, as we all know, they remove one of the shifter cables to get the tranny out. When they put it back on, they didn't adjust it at all, and now I don't have a 5th and 6th gear.
HOW DO YOU ADJUST THE SHIFTER CABLES!?!?!?!?!?
FF Affiliate
If you look at the cables there is a orange button about 3 to 4 inches from where the cable connects , it will push through in one direction and that will allow you to place the shifter inside where you want it when holding it in place (2man job) push the orange button back in place to lock it
If you dont have any 5 or 6 at all there may be another issue other then adjustment, you may want to look andmake sure the cables are in there holding bracket on the trans as well
Across the Pond
I did the adjustment with the orange button and I now have all my gears back. Thanks.
1 - 4 of 4 Posts
