1 - 5 of 5 Posts
I would like to tap a hole in a piece of metal that will be for a ten millimeters (10 mm) machine screw.
The pitch of the 10mm screw is 1.0
All my drill bits are in inches !
What size drill do I use to thread it with a 10 mm / 1.0 tap?
10mm is about 12/32nds but that won't work.
ANYBODY?
WOW ! THANKS for the information -
I didn't realize I was supposed to click on your message -
what an amazing chart Thanks again....
I'm gonna use a 7/16 drill bit -
TARBO-PANDA
No worries, and sorry for not making it more clear it was a link.
There are general rules for hole size, thankfully google is a good friend.
Good luck!
Excellent!
Without all the proper drill sizes handy I often just hold the drill up against the tap to see if the points of the tap stick out past the drill size enough - while still having a drill that isn't smaller than the center solid section of the tap.
1 - 5 of 5 Posts
