1 - 5 of 5 Posts
Sonic Mk3 Crew #03
Clutch has been bled over 50 times. The clutch engages fine at 1/2 and 3/4 pedal but past that it partially lets the clutch out and the car stalls in gear. Full clamp at 1/2 and 3/4 half clamp at 100% depress.
We will try and bleed it some more tomorrow since the starter crapped out from starting the car in gear.
The Ford guys are baffled and all they can think is the cars throw out bearing is over engaging the clutch at full depress.
Noone else knows what to think so Im asking in a more particular thread.
I can't believe you havnt got any replies. I know some one on FF has had this problem. You will get an answer sooner or later. Good luck !!
Vince your Moderator
Slave cylinder is bad IMO. Did you reuse the old one?
1 - 5 of 5 Posts
