1 - 2 of 2 Posts
Hey,
I need help trying to replace the rear 02 sensor. I know am not the handiest guy in the world if I am asking for help since it seems pretty easy by reading others posts. I bought a 02 socket to remove it, but the problem is I can not get it on because the axle gets in the way. Also my combination wrench could was too long and would bump into the cat and other parts. I was wondering the following:
1. If there is another tool out to help out with this?
2. Do I have to remove the cat to get to it? Or the axel?
3. I'm just an idiot and one of my tools should have done the job?
Thanks,
Trump 2016
i just replaced mine pretty simple but slow process you have to just go little at a time i used the 02 tool and ratchet you get maybe little turn at a time keep switching tool to get ratchet to turn also make sure car is hot then shut off car and remove be carefull not to burn yourself on exhaust wear gloves its a slow process but farely simple
1 - 2 of 2 Posts
