Today I tried to tackle my rear suspension to svt setup
On the passenger side lower shock mount bolt snapped in the nut and there’s a little numb sticking out on the outer side but it wasn’t turning
and the control arm to knuckle is loose almost all the way but somehow it got stuck and just spins won’t go in or out with the impact gun
And the nuts are welded on to the sides I think it would be best if I somehow broke or cut the welds on these nuts to remove the stuck bolts and replace all the hardware
Anyone got any ideas
The driver side I used my friends stronger impact gun and everything came off in 20 and put that side back together but the passenger side is being a POS
