1 - 3 of 3 Posts
Just replaced the transmission in my '05 Focus zx4 2.0L. We got everything put back together and now when I turn the key, nothing happens except for the dash will light up, radio comes on, and the headlights will come on. It will not even attempt to turn over. We checked the battery terminals, inspected wiring, made sure everything was where it was supposed to be, but I cannot get the car to even attempt to start. Help?!?![scratch]
Thats What She Said
Did you get the crank / flywheel sensor in correct and pluged in?
Is it an Auto or a Manual? The sensors are different between the two. Did this get swapped over?
Depending on trans type check the starter interlock that stops manual trans from starting in gear and ATX neutral switch if automatic trans.
1 - 3 of 3 Posts
