Checked with obd II scaner getting codes p087a & p087b clutch position sensor b circuit, p0011 intake A cam position timing over advanced bank 1, p0016 crankshaft position bank 1 sensor A, p0017 crankshaft position correlation bank 1 sensor B,p052a cold start intake A camshaft position timing over advanced bank 1,p0300 random misfire,p0301 misfire cylinder 1. Car is 2013 focus it dose run but idles vary low if at all when gas pedal is pushed it will suptter drop rpms and sometimes die it is not drivable. I just trying to narrow things down so I don't replace things I don't need to crankshaft position sensor,camshaft position sensors,plugs,coil packs? So Many places help where do I start
