1 - 4 of 4 Posts
First I woke up to my clutch feeling empty and not working then I am able to shift without it and I park and my starter doesn't work. What do I do to fix both it is a 2007 red Ford focus.
Does it have any pressure at all? Is it sitting on the floor and won't come up? Could you better describe "feeling empty and not working"?
Not being able to start it unless the clutch is engaged is normal.
05 ST -2.5L fusion swap 13 ST - SP63 forged block
It could be that your master cylinder went bad. It’s located underneath the dash on top of the clutch pedal. If that’s not it, then it’s the slave cylinder. It’s located inside of the bellhouse of the transmission. Very big job to replace
1 - 4 of 4 Posts
