Fuel pump fuse? Fuel pump relay? Fuel pump inertia switch reset (passenger side foot well)? Badly clogged fuel filter? Fuel pressure sensor? Bad FPDM (Fuel Pump Driver Module)?
Any CEL (Check Engine Light) codes?
I would suggest if it's running on starting fluid only then you aren't getting fuel to the motor.
