1 - 2 of 2 Posts
I have an 07 Focus, and is has had a major brake issue. The front p-side grabs as I go forward. It's intermittent as when I first start the car and drive I have no issues, but once I've been going for a while it starts to grab. Then after about 20-30 minutes it goes back to kind of normal, with the brake pedal pressing further than normal. I have changed the caliper, on my 4th set of pads and greased the piston. I need help I don't thinks its the master, as the d-side doesn't do anything but act normal. I'm sure the rooter is worn now, as the excessive heat surely has done damage, but I just want to fix it so I can drive. Any help is greatly appreciated. Thanks
Dave
Quite possibly a warped rotor, have you checked run-out on it? Since the rest of the parts are new, I would replace both front rotors. Good luck.
1 - 2 of 2 Posts
