1 - 9 of 9 Posts
Whats the name of the plastic cover that goes over the windshield wipers? Mine is all bowed up and I cant get it to lay flat on the pass side.
Any ideas on how to fix?
It appears the be hitting the pass fender? I could trim it but I doubt this piece has expanded that much. It just looks bad and Im tired of looking at it.[V]
posted in wrong section can the moderator move this...I apologize[:eek:)]
are you talking about the cowl that goes underneath it? sort of has holes in it.....
Retired Fanatic
Replace it, it's it's bowed up, the plastic is screwed, obviously damaged............
Discussion Starter · #5 ·
Sigh[V] . If only I wasnt so cheap.
Hmmm, maybe I could swap with my friends Focus[rolleyes]
it probably isn't seated perfectly. it's a pretty specific fit up there. you might have also broken some attachment pieces, but that wouldn't particularly cause it to bow horribly.
Retired Fanatic
Yeah I forgot to mention, check the mounts, if they are broken, missing, damaged, or maybe loose (maybe).......
Plastic is a bad 'thing'.... when it breaks, it's pretty much comes down to a replace....
Try contacting JEREMY at V6FOCUS (username) on here or at www.focussalvage.com
Retired Fanatic
Discussion Starter · #9 ·
Im getting a new windshield in tomorrow after that I will completely remove the plastic piece and see whats up. I have just been peeking around up till now.
1 - 9 of 9 Posts
